maxum1989's avatar
maxum1989
Explorer II
Oct 27, 2016
DIY pressure test
Well I have a leak in my camper I'm trying to trace down. I am getting water at the front passenger corner at the bottom of the mattress. With it being a Northern Lite camper with full fiberglass the possible locations for the water to get in are limited. As far as I can tell the only locations could be the upper windows, the marker lights up front, or the center seam. I guess I could add the skylight above the bed to that list but I just re-did all the sealant on the roof cutouts this summer. I put many coats of the sealant up there so I am pretty confident anything on the roof is sealed.
At first I was going to take out the two upper windows in the cabover and re-seal them but I am now unsure those are the issue. I think its more likely the water is getting in at the center seam that joins the upper and lower halves of the camper.
I have tried several attempts at using green painters tape to seal up various location with mixed results. I have also tried leaning the camper in different directions to see if I can get the leak to stop.
So now I have decided to do my own pressure test to see if I can really find out the exact location of the leak without guessing.
Here is what I've done. This first photo shows the 1/4 mdf sheet that I cut to the size of one of the side windows. It will be easy to tape it to the outside of the camper with the fans sitting on a table outside. I used a new unused sewer hose that fit onto the fans perfectly. I also have my manometer that I had sitting around mounted through the mdf as well to monitor the proper pressure.
This shows the sewer hose through the mdf which fits quite tight as well. I may not even have to seal/tape these spots. I had to thread it through the holes. The manometer will tell me if I need to address this.
Another shot a little closer showing tubes coming through.
While its been raining here nicely to test the green tape and leaning camper part of the testing, it would be nice if the rain stopped so I could try out this air pressure testing setup. With the camper wet the tape to hold the mdf in place won't work very well. So, here I am ready to test and waiting on weather.
Anyone see any issues with my testing setup?
  • GOOD IDEA.
    Forget soapy water. On cars vacuum system leaks, I advise a cigar.
    If you want quality test, make it Cuban cigar.
  • I had a lot of leaks in my NL. Non were the clam shell seam. Take the interior trim off the escape hatch and see if you feel any moisture. But first check the window vents as they mold up with dirt and the bottom window channel won't drain outside but inside instead.
    Remove marker lites and caulk around the wires going thru the fiberglass body. Caulk screws and lite base mounting.
    thank you for reminding me as my front side window vents need cleaning and have been leaking inside.
  • How many PSI do you think you will get? Are you going to soap the area where you think the leak is?
