TomG2
Jan 11, 2018Explorer
What does RAM say on the subject? If it was a GM product, they would state that no WD hitch is required for that setup and they might know a little bit about towing.
You are about to hear where it is so much fun to mess with a heavy, dirty, and noisy WD hitch that you will want one regardless of the loads involved.
By the way, the myth about front axle weight is still around from the old days when we towed with sedans and station wagons. A one ton diesel pickup has plenty of front axle weight bias. Note that manufacturers don't install ballast to the front end when they switch to a much lighter gasoline fueled engine.
44,070 PostsLatest Activity: Aug 05, 2026
