smcrea
Feb 08, 2015Explorer II
Do I Need to use a WDH with an F350 SRW Powerstroke?
I've finally ordered my new truck!!.. It's an F350 Diesel 6 3/4' bed, SRW, snow plot prep, big cab.
The specs fro the truck are in no small part due toy the input from you good people on this forum
THANK YOU!!
This is an overkill for my current trailer. However I got the F350 because it's possible that we could get a 5th wheel toy hauler at some point.
For now my trailer is a 27' from the tip of the tong to the back of the bumper
I don't know what the tong weight is fully loaded because I've never put it on a scales.
However the brochure says this:
Axle Weight (lbs) 4,350
Hitch Weight (lbs) 550
Dry Weight (lbs) 4,900
Cargo Capacity (lbs) 2,650
So I guess the max GVWR is 4900+2650= 7550Ib (Is that correct?
Is it possible to approximate the tongue weight fully loaded from this data?
My question is:
When we get the F350 will we still need to use a Weight Distribution hitch?
Or another way of saying it is "What is the max tongue weight the F350 ca comfortably tow"
Currently with out 1500 suburban we use and equalizer WDH hitch and it's served us well. However it is a bit of a pain when doing tight turns and taking the darn thing on and off.
If my new behemoth of a truck can tow this 'easily' without a WDH then obviously my choice is to not use one.
Any advice from you experts?
Another reason is that IF I have to use the WDH then I would have to order another ball and adjustable hitch which are NOT cheap!.. I may still use the suburban to tow back and forth from home to storage so I don't want to have to keep taking it off and refitting and re-adjusting the hitch system between TV's
Thanks!
Steve
THANK YOU!!
My question is:
Thanks!
Steve
