Grit_dog
Mar 25, 2017Trailblazer
Your truck is easy to put lowers in because there's a hole in the leaf.
If you do that though, the upper overloads may not even engage. Then you're just leaving some spring capacity on the table.
If you're happy with the ride height, get a sway bar , imo. Sway bar will help more with the top heavy rocking than blocking the springs.
You can try some simple lower blocks, or even make permanent ones easily for cheap.
My material of choice is plastic felling wedges. Drill a hole in each one. Countersink a bolt into it and bolt them in.
