Seattle_Lion's avatar
Seattle_Lion
Do we still need water pressure reducers?
My misadventures with the new Kodiak 279RBSL forced me to learn more about my camper's plumbing than I might like. What I did learn is that Dutchmen and others no longer use PVC and CPVC for piping. They use PEX which is a flexible, reinforced tubing used in the home building industry. PVC pipe came in different wall thicknesses. Residential housing normally required schedule 40, which could easily handle over 100psi of water pressure. As I understand it, the RV industry used a much lighter (thinner walled) piping that couldn't take high water pressure. Did I get this right?
PEX, as far as I know, is pretty standard. If crimped properly, it routinely handles the same sort of pressure as schedule 40. I find it hard to believe that the RV industry is using some sort of inferior PEX that has less ability to handle water pressure.
If this is the case, could it be that the need for pressure reducers has quietly gone away? One argument in support of this is that there were no warnings about excessive water pressure damaging the camper. My new camper was literally plastered with warnings about other stuff. The lawyers really got into the RV business!
I am using a pressure reducer because it seems to be the right thing to do. But now that I have spent some time thinking about this, I wonder if there is any definitive evidence that this is or isn't necessary. The Dutchmen manual hasn't changed in years, so any suggestions from it might not be correct any longer.
Any good information?
Bob
  • Newer RVs using PEX piping usually are rated for 60 PSI of water pressure. I've seen MANY campsites where water pressure was close to double that. Older units were generally rated for 40 PSI.
  • I attach the regulator to the hose on the faucet end. That way, it is less weight hanging from the plastic city water connector (a 90 degree elbow helps out here -- less torque), and it also will help protect the hose.
  • 2012Coleman wrote:
    You already bought it - why not just use it? In addition, I also use a 90 degree elbow so the regulator attached to the hose is hanging down.
    me too
  • My trailer has a built in one, though I use a pressure reg anyways.. Once I was camping in Nauvoo, IL, and forgot to use it. The pressure was INSANE, and actually slightly ballooned the end of my hose. The hose was usable, but wouldn't roll up properly anymore.. I had to replace it.. The trailer was just fine. I use the regulator all the time now.
  • Always use a pressure 'regulator' preferably a good quality adjustable one like Watts Brand.
    Set the regulator for 50 psi (static...no flow) and you will be good to go.
    We have run into various water supply pressures........sometimes really low (30#) and sometimes really high (100#...plus). And then there are those times where it fluctuates depending on park usage.
    With the regulator in place no worries..........50# MAX regardless.
    Note: RV pumps have discharge pressures between 45-55#
    PEX is great.....fittings etc. so-so
  • You already bought it - why not just use it? In addition, I also use a 90 degree elbow so the regulator attached to the hose is hanging down.
  • Its not the PEX that is the main issue, its filters and faucets. Most are rated to 60b psi max. Valves in ice makers are also a weak point.
    PEX is rated to withstand 100 psi at 180 degrees F.
  • the pex is not the problem it is he vacum breakers that cannot take high presssure like the shower and toilet.plus the more pressure the faster you will use your hot water.
  • No, you still need a regulator because the faucets and water filters are not rated for more than 40~60 PSI.
