Cummins12V98 wrote:
maxwell11 wrote:
if you can afford it.
get a truck with the exhaust brake and 6 speed auto transmission
I have the 05 model dodge
was standing on the side of the road the other day waiting for the tow truck, #5 fuel line blew out. 92K miles
what a pain in the butt
going down a hill with a heavy load better have good brakes as it will push you with no exhaust brake.
only a 4 speed and no lock out for 4 th gear on a 05 model, what were they thinking????????????????
Good reason to belong to the TurboDieselRegister.com. You would have known about this common problem and had it replaced or had a spare to replace when and if yours went bad.
FUEL INJECTOR LINE #5 - CUMMINS ('03-'07, 5.9L)
$31.00
The problem was they vibrated loose causing them to break. Simple thing is to keep a check on the clamps every oil change to make sure it's tight.
