thomasmnile
Apr 19, 2014Explorer
Bluhorn wrote:
Sorry you have had a bad experience.
Wintersuns post has no merit as any rant on any other manufacturer......With a few exceptions of course. You cant go wrong buying any of them.
When I bought the 3500, it was only 3 years old and had 20K miles on it. Previous owner had towed a fifth wheel with it as I did once I bought it. The powertrain has been perfect, even the often maligned (on this forum sometimes) 48RE transmission has been flawless. 73K on the odometer now.
I beg to differ, but water leaks into the cab from multiple locations, needing a complete front brake job at 44K including replacement of cracked rotors, a leaking AC refrigerant system that has so far defied attempts to isolate the source, upper control arms, sway bar links and bushings, & a grenaded power steering pump are hardly 'run of the mill' issues, and some of them I view as very deficient in build quality/design and more than 'expected' maintenance.
