3 tons wrote:
According to TCM, for 2020 Ford has ‘quietly’ done yet another diesel redesign (block, heads, injection, etc) their 6.7 Diesel...Huh?? Seems that each generation is fairly short lived - why is this??...Dealer service depts must spend lots of time doing re-training...Nice trucks no doubt, but every since it was reported that they have to remove the cab to work on the engine, not really my cup of tea...
I don’t think TCM would generally be considered a top source for Fords, but any way.  They take the cab off because it’s actually smarter.  It’s designed to come off.  If you do some research, you’d know that it’s actually only 45 minutes for an experienced Ford mechanic to lift the cab out of the way.  That makes easy access to almost impossible to reach items otherwise.  Unless you compare on/off timings of several jobs, you really don’t know anything about why taking the cab off makes sense.
If you’ve been following along, Ford will be introducing a total redesign 7.3 gasoline n 2020.  GM has a redesign of the diesel and gasoline engines, and Ram just redesigned their 6.7 for 2019.
As far as DEF generation goes, it’s certainly better than the other heavily modified engines to improve emissions, but still not anywhere close to as troublefree as the engines without the DPF or the DEF/DPF combination.
