rhagfo
Jul 26, 2019Explorer III
Grit dog wrote:
"Use all the time, or it will carbon up.
Is that a real fact, or myth?"
It's a myth. VVT's go through the same motions everytime you punch the skinny pedal as they do when the e brake works, except in reverse.
Using the exh brake will not do any more than just driving it to prevent the turbo vanes sticking.
Now that is true of butterfly valve exhaust brakes. If they remain static for alot of hours/miles, they could cake up and stick theoretically.
The Cummins VVT turbo uses a sliding ring for the exhaust brake. I use mine every time I drive the truck. That is the rings only function, to that point even in the Fords and GM, why not use it all the time to save on your service brakes.
