Bluhorn
Apr 20, 2014Explorer
thomasmnile wrote:Bluhorn wrote:
Sorry you have had a bad experience.
Wintersuns post has no merit as any rant on any other manufacturer......With a few exceptions of course. You cant go wrong buying any of them.
When I bought the 3500, it was only 3 years old and had 20K miles on it. Previous owner had towed a fifth wheel with it as I did once I bought it. The powertrain has been perfect, even the often maligned (on this forum sometimes) 48RE transmission has been flawless. 73K on the odometer now.
I beg to differ, but water leaks into the cab from multiple locations, needing a complete front brake job at 44K including replacement of cracked rotors, a leaking AC refrigerant system that has so far defied attempts to isolate the source, upper control arms, sway bar links and bushings, & a grenaded power steering pump are hardly 'run of the mill' issues, and some of them I view as very deficient in build
quality/design and more than 'expected' maintenance.
I understand your feelings and respect your opinion, but yours is the exception not the rule or they would all have these issues. The brakes are indicative of how the previous owner drove it. The rest, who the heck knows. My front brakes have been replaced at 80K intervals, rotors turned and still are original rotors. Back brakes are original. Everything is original except blower motor. I would be unhappy if I were you too. I hope it gives you long service , cause these things are not cheap wheather new or used.Enjoy your day and have a happy Easter!!
44,070 PostsLatest Activity: Sep 18, 2026
