PackerBacker wrote:
I'm still debating whether or not air bags would help my combination. I'm still within my limits and with my Equal-i-zer WD hitch, I'm perfectly level with the weight transfer bringing my front fender height back to exactly where it is before hitching. :C
I'm wondering if bags would work against the efficiency of the hitch in my case. :h
... Eric
If you have a soft, wallowing ride even with your WDH setup, bags might help. Also heavy duty shocks, and the stiffer side walls of LT tires will help with tire squirm. None of these replace the WDH.
You adjust your WDH *after* any changes in your suspension though. So set the bag air pressure for the ride you want, then adjust the WDH to bring the front fender back to where you want it.
