ifd22
Nov 28, 2018Explorer
mowingman wrote:
So far, not too impressed with the transmission in the diesels. I have a 2016, 2WD, 3500 pickup. It is currently in the shop with transmission problems, at 65,000 miles. The book says to change trans. oil and trans. filter at around 60,000, so being a by-the-rules kind of guy, I took it in for service. About 10 minutes after I picked it up at the dealership, a check engine light came on and the trans. did not downshift properly. Dealership says some valve in the trans. is bad, and they are dropping the trans. and repairing it under warranty.It is not the Asin trans., just the normal trans. they commonly use in those trucks.
So, I am not real happy about this. On the other hand, it could have gone out while pulling the 5er about 1000 miles from home. Oh Well, it is warranty.
I think they are pulling your leg, it’s a little coincidental that you had issues within minutes of picking it up. My bet is they didn’t properly seat your filter which is common with the 68rfe. It sounds better on their part to blame the transmission then to blame themselves.
