lonetow
Sep 16, 2013Explorer
Yes it works pretty well just up in the dash as far fwd as possible, cuts out every once in a while for a second or 2.
Thanks for the help though
goreds2 wrote:lonetow wrote:explorer0863 wrote:
This article is not specific to Dodge, but it should give you a pretty good idea in what you can on your Dodge.
Click here
Here is the link for the adapter that you may need, depending on your set up.
Adapter
I hope this is helpful. Good luck!
Thanks for the tip on the adapter, I went ahead and ordered this one antennahoping it would work
Did it end up working out? Here is a SIRIUS antenna that is used on semi's. Not sure if yours is compatible or not.
Tram Sirius Antenna
