ShinerBock's avatar
ShinerBock
Dodge/Ram HD truck specs 2003-2019
Got really bored at work today and curiosity took over after discussing specs with a co-worker who had an older 3500 SRW. He did not believe me when I stated that the 2014+ HD trucks with the new frames essentially took the specs and ratings of the class above it. Meaning the 2014 2500's basically became prior 3500 SRW and the 2014 3500 SRW became prior 3500 DRW.
He also didn't didn't believe that prior to 2007, all SRW 3500 were in the same 2b truck class as the 2500 3/4 tons due to their sub 10k GVWR. Added 2019 numbers in there as well. Surprising that the GAWRs on the 2019 2500s went down, but everything else went up.
Figured you guys would want to see as well.
PS: This info did not take that long to get since we already had the Ram bodybuilder charts in our system. A quick v-lookup auto-populated most of it for me.
  • Just two thoughts/questions....having a "classic" Dodge 1 ton dually V-10 1996 vintage which I bought to tow with way back when but ended up with a motorhome(its has 26,000 original miles) I certainly see the Large difference in towing capacity today compared to back then!
    Secondly, a friend just retired. He wants nothing longer than a 35' Fifth wheel but he also wants a quality one(meaning heavier). Honestly I don't follow the latest trends but I've been telling him for years to get a dually 1 ton ….so he comes up to spend a couple day with us, in his new 2018 Dodge 2500HD Diesel 4wd....very impressive single rear wheel. I'm happy for him but at the same time question it? He tells me towing capacity is roughly 17,000 lbs and Pin weight of 2500 ...and some of the 5ers I
    ve looked at in his price/size range push 15-17,000 lbs with Pin weights close to or over 2500
    I don't want to rain on his parade cause I alwals figured you should more truck than needed....am I wrong? or will he be OK? He's very impressionable and I'm sure the salesman told him it could tow anything!!! Just looking for opinions….Like I said, I don't keep up with it all as I use to. ( a footnote, I tried directing him to a used F-650 with a 300hp CAT Super Cruzer in mint condition. That would have been plenty of truck although a 2005 with 60,000 miles).
    On edit....that 2005 even in the 650 class has less of a tow rating than I expected?
    He shouldn't have a problem with just about any 35' or under fifth wheels. Even the Arctic Fox ones, which are quality units, tend to run in the 15k gross range, and retired generally means two people not a family with associated stuff to carry. His rear axle rating is 6500 lbs which should allow over 3000 lbs of pin and hitch weight, and frankly he could bump that up a bit with timbrens or bags (imo). I wouldn't worry about it.
  • Come to find out his payload is 2200 lbs....not so good for a fifth wheel if you want to stay within weight limits. I'm done suggesting anything because at this point no matter what I say, I'm picking on him for his error. I did check his dealer inventory and they had a number of 1 ton and 1 ton dual rear wheel available all in the New 2018 category. Went looking on Sunday at fivers and everything he liked was over his weight limit but of course the salesmen were all saying, just add air bags and your fine...LOL!
    He's a hard head so as it stands he will end up with an Ultra Lite fifth wheel(about the same quality as his bumper pull he sold last year) whereas he could pull just about any decent bumper pull he wanted...BUT No way!! May as well compound the truck error with an RV error!
