rastaman33609's avatar
Jan 27, 2014
does 2 #8 wires equal one # 6 or #4 for added battery
Well I know I should have used # 4 or#6 wires, however I will only be charging 1 battery (or 2 6 volts)in the TC. Using my Dodge 3500, the connector I am using between the Truck and the camper can take 3 #8 wires.Will I gain anything if I ran 2 #8 for the Positive. and 1 #8 for the negative.
Just to be clear I understand the benefit of the heavy wire, however as my power needs are somewhat limited as was the budget and as I already had the #8 wire, I just wondered if i would gain anything.
Thanks
  • Back in the day when I was a comm tech,If we doubled 8 GUAGE,it was something like 7 guage ,wasn't a 6 but better than 8.
    also run the shortest route to frame for ground and clean off paint and use a star washer if you can find one. Fuse for 40 amp as close to batt as possible.
