larry_kruzan wrote:
FishOnOne wrote:
Looks good to me. If anything I like to have a little bit of tilt to the front for a conventional trailer.
Why??
If the TT is level the load on the tires is even. If you're nose low the front springs and tires are being loaded heavy. It will lead to the front tires running hot on a long pull
It doesn't matter. The equalizer bracket is there to "equalize" the load. Both axles will always have equal weight. Now on a trailer with torsion independent axles, thise need to be level!
