brnthumbinfl wrote:
We purchased our 2019 Mesa Ridge 21RBS TT from Lazy Days in Tampa, January 2019. We've had it in twice for warranty repairs. Both times, we reported the AC unit would hover when it reached the set temperature. Particular at night, the unit will cycle on for as little as 10 seconds then cycle off for 10 seconds. Back and forth as many as a dozen times. The unit is not terrible quiet, so this gets irritating when you're trying to sleep. Plus it can't be good for the unit.
Lazy Days checked it twice without finding anything wrong. Of course it was winter when the unit isn't really working. They tried insulating the thermostat, then I forced them to replace the thermostat. Neither action corrected the problem. Currently I am beginning to think it may be the unit itself. It seems when it goes into hover mode, I'm not sure its really cooling as the air seems just room temp.
Any ideas?
Brnthumb
Are you sure it is doing it a "dozen times"
If you read your manual, you'll find out that it is normal and is adjusting itself to a lower speed once it reaches the set point.
Guy
