ScottG
Jan 10, 2015Nomad
Old-Biscuit wrote:ScottG wrote:
Yes wind both ends and I would turn it another couple of turns because you will find 8 turns is very weak.
As your turning the side that doesn't lock, don't get your head and face over the tool!
If one side has not be unwound then no need to rewind.
Number of turns is dependent on size of awning.
Pretty hard to change the fabric without unrolling the awning. Probably doable but would be much harder that way.
If you have actually done this job you will find the "Number of turns" stated is not enough and even the manufacturer doesn't follow their own guidelines.
