jsc253
Sep 26, 2020Explorer
Dometic Compressor Fridge Issue
I’m hoping to tap into the membership’s vast knowledge. I own a 2 year old Northstar TC650. It was optioned with the compressor fridge based on all the good reviews and pluses over the absorption models. It seems to have worked well until now.
I started it up and after a few hours checked the temp in the freezer and fridge. The compressor was constantly running and the fridge never got below 50 degrees. The freezer got to -13 degrees. Thinking it might need more time to cool, I left it on for 24 hours with the same results. Clearly the cooling system is pumping but the coldness isn't making it to the fridge. I’m guessing the thermostat is somewhere in the fridge and it never gets cold enough to tell the compressor to stop. I turned everything off and let the fridge sit for a couple days and then fired it up again with the same results.
I have done an internet search and very few problems with these fridges have been documented and none describe what I am experiencing. I’m hoping someone can shed some light on this. I have called a couple RV repair Techs and they have no knowledge of compressor fridges. I have reached out to Dometic and still waiting for a response. Thank you in advance.
