carringb wrote:
eHoefler wrote:
Try closing the valve on your propane tank and bleeding off the pressure, then open the valve very slowly. It sounds like you might of trip the excessive flow protection valve.
I've had this happen. If you trailer has no propane pressure when you hook up a tank, then you open the tank quickly, it'll do this. Stove will make flame, though it's weaker. Big appliances won't work.
OP - Are you getting airflow? Does the air warm up at all? I've seen some trailers where the intake was blocked, causing the high temp circuit to trip because there wasn't really air moving through the furnace.
Or,, maybe all his outlet ducts are covered so that no air can get out of the furnace.
