Old-Biscuit
Dec 24, 2020Explorer III
Lynnmor wrote:
I don't know what toilet the OP has, Dometic has 300 series toilets with model numbers of 310 and higher. The black seal and the flush valve are replaceable in this series, any other problems require a complete toilet replacement.
Dometic has:
300
301
310
311
320
321
Plus 500 series, 5000 series, 8500 series, 8700 series, etc, etc
OP stated they had a 300.....info concerning the bowl seal was posted
Dometic 300 Series were recalled due to leak between factory sealed bowl/base assembly.
To confirm if your toilet is part of the Dometic recall, check the toilet model and serial number on the label that is located on the toilet base under the water value. Have this information available when you call their Service Center at 800-321-9886 from 8 a.m. to 5 p.m. (ET).
** Usually can upgrade to 310 Porcelain Bowl----just pay upgrade fee
