1960something wrote:
Thanks for your responses. I've not had any trouble before with my old camper. I googled dometic series 300 and appears there might be a design flaw. I will call dometic tommorow. I do think its got something to do with the connection of the toilet.
Ok, I see. You are talking about the actual toilet (like you said, sorry). When you say "bottom of toilet", are you referring to above or below the flush ball?
So if you hold the flush ball open, the toilet paper won't go down the pipe? Isn't this a gravity fed toilet and as long as you hold the valve open, everything should go down the pipe!
What is the paper hanging up on? I just don't see how it can be a design flaw unless the paper is hanging up on something "below" the flush ball and that could be something not installed correctly or something someone has stuck down there. Have an little kids using this toilet?
Ron
