Gdetrailer
Sep 13, 2013Explorer III
Sounds to me like the "air gap" at the TOP of the toilet may be holding fresh water after you flush. It is supposed to drain out after the water is turned off at the end of the flush.
In some cases you can take the top of the toilet off and you will see where the water fill valve squirts water across a open space into a channel, this is the air gap. The channel then goes around the top of the toilet bowl and spills out into the bowl.
You may have a miss shaped part that is holding water after the flush and when traveling it splashes out of the top and onto your floor.
44,066 PostsLatest Activity: Mar 14, 2015
