travelnutz
Jun 19, 2016Explorer II
Many campgrounds BAN removal of a TC from the truck and more are or are being required to by state or local laws etc. More and more common! A TC is not and actual RV as defined by most state etc laws/rules/codes because it has NO wheels or capability of rolling on roads or being moved quickly or reasonably if need be for any reason. Once an TC is removed from the truck, it becomes a stationary planted structure that's not removable by towing and doesn't meet state or local codes.
I know for a fact that the axles and wheels must be left on any and all RV units and a current license/registration must be attached in Michigan when in any CG or public land as I was on the board of directors for 9 years for a very large RV CG and Resort and the state laws were enforced and fines issued for non-conformance by the county sheriff. Seen it many times! Sometimes a warning was given first to comply within X time or the warning would become a citation and the CG got a copy. Simply put, a TC off the truck/carrying vehicle not being on the owners property, a dealer's property, a repair facility, licensed storage facility, etc is deemed to be an abandoned item and NOT an RV because it is NOT a VEHICLE! Just a structure!
Also, so many old or dilapidated/broken jack systems etc TC's have been abandoned in CG's and/or on state or federal land usually with the serial no. identifications having been removed or totally obliterated to prevent owner identification. Many states didn't or don't issue required titles or registration for TC's. Then the CG owner or local Gov or state or federal Gov has to pay the cost for removal after going thru the long process of getting full authority or court approval to do so. In a CG, this renders the campsite space unusable and an eyesore until removal is actually done.
AS a constant TC owner for over 50 years now and on our 7th TC, I fully agree with not allowing a TC to be removed in a CG or on public land as it's only an RV when on the carrying vehicle. A ~100 sq ft box with no wheels simply sitting on the ground can not be classified as an RV nor an occupiable living structure by humans in any U.S. state I'm aware of. Doesn't meet the codes and check yours!
