Old-Biscuit
Aug 24, 2015Explorer III
The Vehicle Certificate Label certifies vehicle conforms to Fed Motor Vehicle Standards.
Then it states: The label also lists: And go on to list 9 items.
One item is Gross Vehicle Weight Rating. (And this is key-----that sentence ends with a PERIOD) THEN it goes on to describe that the F/R axle weight ratings are based on minimum rim size and cold tire pressure.
Based on THAT sentence structure......GVWR is one item LISTED on 'label' and F/R AWRs are other items listed WITH a caveat on how they are determined.....not on how GVWR is determined.
And I understand that the data was from a 2004 Ram Service Manual but YOU posted it therefore by extension it is YOUR example.
Hence my reference: In your example.
