APT wrote:
If payload is your concern and you prefer the Ford, why not the F350? Should have about 1400 pounds more payload for the same equipment as that F250 you looked at. Unloaded ride should not be affected. Cost should be about $500-800 more for the same equipment. You may prefer to order as in my area single rear wheel 1-tons are not stocked as much as 3/4 tons.
I read this too quickly the first time through. The important point you made is "same equipment" which will be really hard to do.
I was visiting my local Ford dealership a few weeks ago and was amazed to see an F350 in the showroom with only ~2,000 lbs of payload after all the factory options.
