rbpru wrote:
About a month ago I went to an RV show and they had two Ram 2500 4x4s on display.
Since I am at the limit for my F-150 4x4 's payload of 1411 lbs. I decided to see how much more I could gain with a 3/4 ton TV.
One of the Ram 2500s had a cargo capacity of 2100 lbs. the other was 2300 lbs. for me this would be a payload gain of 700 to 900 lbs. This would be fine for my 25 ft. TT bit I do not know about some of the 5vers I see.
That is the beauty of the yellow stickers. It doesn't matter what the salesman or some guy on the Internet has to say, if the numbers don't work for you, you can figure it out yourself. Calling a F-300 a F-100 doesn't really matter. If you need 3,000 pounds of payload, then get it.
