PUCampin wrote:
1968lbs is "just for the cab" WOW! Don't know what to say...
The Tire and Loading Information sticker is for THAT SPECIFIC truck model and package as equipped as it rolls off the assembly line. Includes full fuel, but no driver or passengers. It is required by law to be within a few pounds of the actual weight if you randomly picked one and weigh it. The sticker states exactly "The Combined Weight of Occupants and Cargo Should Not Exceed XXXX" That means EVERYTHING put in and on the truck counts against that number. If the dealer or aftermarket upfitter adds anything more than a few pounds they are legally required to make get a new sticker.
"The Book / Brochure" just gives the number for a basic truck, what the maximum possibility is. It doesn't list how much each option reduces the number. For example, there is a model and package of F150 that has a payload over 3000lbs! Will you find it on a lot? Not likely. The sticker on the truck represents it as it sits.
It is surprising how low those numbers can sometimes be, and usually you see it on top of the line diesels. The diesel engine weighs A LOT more than the gas engine, so that is part of it, and all the components of the fancy packages weigh in as well. A gas engine XLT will have a lot more payload than a diesel Platinum. Good luck with your hunt!
Correct!
I am always puzzled as to why anyone would intentionally buy a F250 configured with a Diesel engine plus 4x4 and any other cab size than a regular..
There is one heck of a lot of weight added to the vehicle with diesel and 4x4 which reduces the overall payload..
F250s are limited to a max of 10K GVWR, anything you can do to reduce the weight of the vehicle gives you more payload..
In my case, 2013 F250 2wd, super cab, short bed I have 3415 lbs of payload.. add diesel and 4x4 It would be just a bit over 2K payload..
If you REALLY NEED diesel and more than 2K payload you have to look at a F350 WITH A GVWR HIGHER THAN 10K lbs..
Care needs to be taken when playing the payload game with F350s, since they have 10K, 12K, 14K GVWRs..
Not to mention some states you will find yourself in commercial tags and higher insurance..
If you don't NEED diesel, a F250 can be had with much higher payloads..
