JBarca
Jan 26, 2014Nomad II
Ron Gratz wrote:myredracer wrote:The upper limit of 15% originated with tests conducted in 1979 using subcompact, compact, and intermediate cars as tow vehicles.
Everyone out there says your tongue weight should be between 10% and 15%, but exactly why the 15%?
If the tests were done today with modern tow vehicles, the numbers probably would be different.
Ron
I'll add some to what Ron has posted.
First off, Ron being "King of the best links!" :C Linked us to this site a while ago. http://www.edccorp.com/library/techref.html
Some of us as are as curious as others... (not mentioning any names) follow those links and read them too.
Back in 1979 NHTSA hired EDC an engineering firm to study towing dynamics related to autos having towing accidents of the time. If you scroll down that link, there are 4 volumes under the Library Ref number on the left. # 1081, 1082, 1083 and 1084 related to car and trailer handling and braking studies. If you print them all out, it creates a stack of paper 1" thick printed on one side. Ask me how I know....
Here back in 1979 a lot of the same things we are up against today where talked about back then. Some came to be common place, others seems to be mothballed. Like the recommendation that the TV mass be larger than the trailer. H'mm, a study done and recommended that?
The topic of tongue weight came up too and there was even calculations concerning the length of the trailer tongue on how it affects trailer towing stability. By lengthening the trailer tongue extension, less weight is needed to be held by the TV to have the same stability as it's shorter standard A frame setup.
For example, the standard A frame has a 50 deg inclusive angle and the majority of our TT's are setup on this 50 deg tongue that has an extension of approx 32 to 40" from the face of the TT body. And now the V noses are even closer to the ball. There is not an exact set standard on how close the TT end cap is to the ball, however the 50 degree A frame with the ball coupler at the end seems to be the way to build a camper.
If the trailer front end cap stayed the same length from the TT axles, however the ball coupler was extended for example, 4 feet more, an increase in towing stability would occur and less TW need to be held by the TV. This may look a little "different" and it backs up more like a PullRite hitch, however it is a very passive way to get out of the 10 to 15% TW range. Do not know exactly why this principle didn't take off, maybe too radical a thinking, costs more for the steel to make the frame, camp site length issues or there was some other towing dynamics that did not come up in that report.
Since the industry seems to be stuck on building trailers with the shortest possible A frame and ball coupler distance from the main mass of the trailer, 10 to 15% will most likely be here for a while.
My prior camper started out with a 14.5% dry tongue weight. When I loaded it and was still ~ 800 lb short from being at GVWR, I was over 20% TW per GVW.
The current camper I have now, has a 16% loaded TW and that is after I rebalanced it to get more storage space aft of the TT axles. It would of been in the 18% range if I had not.
Floor plan, TT axles location and where you can load camping gear drives the TW from where the TT dry weight starts from. In my case both of my campers have been rear living area campers. That nice big picture window and 2 swivel rockers in the back do not do much to offset all the cargo storage space upfront so the TW rises quickly. Some brands are now changing the axle position because of this high weight rise to mate up with smaller TV's on this floor plan.
As was said the truck has to be able to handle a 15% or higher loaded TW. And as was also found in some cases, the TT A frame has to be heavy enough to not fail under 15% loaded TW from a WD hitch.
Other than the Jayco special ultralight weight TT frame of years back, and the Forest River Back Packer TT series, those are the only TT's I have seen with a rating sticker not to exceed 1,000# loaded TW. Never talked about TW %, only loaded TW.
Air Stream may have some kind of rating. I declare I have not seen that many Air Streams however read of the concerns of heavy spring trucks when towing them in some cases can cause problems with the A frame.
Does anyone here on this post know what your A frame is rated for when using a WD hitch? Anyone? Have you seen it as a rating in writing from the manufacture? Can it handle 15% TW with a WD hitch?
John
44,068 PostsLatest Activity: Jun 10, 2026
