rgnmgrExplorerMar 15, 2017Drain line capsI needed to replace leaking water drain line caps on my 2014 Keystone Bullet. The drain lines are Red and Blue. That means they are Pex. Only Pex parts will work. After some research I located 1/2...Show More
Bucky_BadgerExplorerMar 15, 2017I cut the pex lines and used "Watts" (similar to shark bite) push on valves..no more caps for me
Related ContentLow point drain line caps nightmareHouse battery drainTurnbuckle blocks gas capDraining water linesPropane Line capping?
