brulazExplorerMar 23, 2014Drain Valve LubeI used Silicone spray on the valves in the old trailer to keep the seals from sticking. They were readily accessible. The new trailer has them stuck way up in the covered "basement". IIRC somebody ...Show More
thib2722ExplorerMar 24, 2014I use white lithium grease on mine and then work them back and forth until it is smooth again. You can find aerosol grease with a straw.
Related ContentCoachmen Freelander low point drain valveGrey water tank won't drain completelyWater drain valvesValve for draining freshwater tankLow Point Drain Valve Replacement
