brulaz
Mar 23, 2014Explorer
Drain Valve Lube
I used Silicone spray on the valves in the old trailer to keep the seals from sticking. They were readily accessible. The new trailer has them stuck way up in the covered "basement". IIRC somebody ...
brulaz wrote:
The new trailer has them stuck way up in the covered "basement". IIRC somebody here has managed to stick tubes up to the valves and use compressed air to force Silicone lube up onto the valves via the tubes.
