SAR Tracker wrote:
agesilaus wrote:
.....If you have a good 1/2 drill motor then you might find a 2 inch metal bit. It will not be cheap tho.
A place where I volunteer just had a need for a 2" bit.... $274 for one bit to drill 6 holes thru 3/4" plate. And we had to rent a magnetic mount drill with a 3/4" chuck.
They do make hole saws for metal...
Where do some of you come up with these ideas that a bit to drill simple steel cost $274!
I have used Blu-Mol hole saws to drill stainless counter tops and sinks! I use to get an easy 10 to 12 1-1-2" holes with a single bit with cutting oil and using slow drill speed!
$9 Blu-Mol 2" hole sawNo you don't need to spend $274 more like $10 to $20, but Amazon. HS it for $9!
