portscanner
Aug 07, 2020Explorer
Kayteg1 wrote:
The spot you mark 99% will go between the lumber, so you have aluminium roof with 1/4" plywood to drill, than Styrofoam and inside paneling to drill thru.
Again, with small wire size, I don't see any problem drilling at any spot.
My 20 yo Lance had some water penetration under the awnings screws (put with no sealer by factory) but roof was perfectly solid.
Hope you have it solid as well.
For sealing the wires, I would make a loop going slightly above the roof level and use lot of polyurethane sealant.
Seems all joints at low level, where the water might stay is a trouble waiting to happen.
Thank you !!!
