Innacanoe's avatar
Innacanoe
Drilling holes in TT wall
I'm really new at this camper thing so am probably making a ton of mistakes. I've been updating the curtains in the camper (19' hitch pull) and tried to install simple little curtain rods over the windows. It seemed as though the walls were made of iron. I managed to drill holes in only two out of eight screw holes but now I'm worried that I may have made holes where I shouldn't have. I know this sounds dumb, but I really wanted curtains. Lol. Btw, its a used 2006 Coleman with no user manual so I'm pretty much having to figure things out the best I can.
  • Some TT manufacturers use steel plates over the wire routing in the studs, so a worker does not drive a stable through the wire during assembly.
  • You might try a stud finder, when you drilled I am willing to bet you hit wood (the window is framed).
  • RoyB's avatar
    RoyB
    Explorer II
    Just fill the unused holes with wood putty and when it dries touch-up to match the decor...
    Hopefully your curtains are not heavy items as the walls are really thin. They are not designed to hold much weight. Maybe your drilling close to the windows was all into framework behind the walls.
