jimh425 wrote:
You can easily drive fire roads with a DRW. Other than narrow roads that might be too narrow for the extra tires, a DRW should be fine. Keep in mind that fire roads are generally made for bigger trucks and of course, logging trucks are even larger!
The biggest limiting factor is probably height and weight of camper which will be the same whether you have the SRW or DRW.
That's a very good point about logging trucks and fire truck paving the way on these roads.
What about rocks between the back tires...where do you draw the line when exploring the trails?
