Hi,
To get the best price assemble your own "kit". I.E buy panels, buy wire, and buy a controller. Because of the Peukert effect, two batteries used together will last more than twice as long as when they are used one after another. Balanced wiring is a "must do".
Here is a simple flow chart.
Budget-->Energy Audit-->Battery bank size-->number of watts-->PWM or MPPT. What ever type of controller is chosen, make sure it has adjustable set points and a temperature probe that is on the battery.
One rule of thumb is between 60 and 150 watts of panels per 100 amp-hours of storage. The smaller the battery bank the higher the wattage needed (per 100 amp-hours). Here is a link to the rather special spreadsheet which includes an energy audit, that N8GS has created to help size solar battery charging systems!
Solar Spread Sheet N8GSFor a nice explanation of solar, try this link:
Golden rules of solar
