Tiggs's avatar
Tiggs
Dual Axle Leveling Question
The space between the TT tires will accommodate one leveling block but if the side to side difference is more extreme I can't place two side by side with a third on top to build a ramp to level both wheels. Trying to roll up on two stacked on top of each other just pushes the block forward. I was thinking of having a 1x8 board cut to length and somehow attaching at least one leveling block (and maybe a half of one) to it to keep it from slipping off... don't know if this would work, not sure how to attach it firmly without risking a tire puncture should it fail so I'm hoping some of you have already found a creative fix and you'll be kind enough to share.
    Don't try to build your "ramp" between the tires. Leave yourself enough room to pull up (or back up) about 5 feet, then build your ramp either in front of or behind both tires. Then pull up (or back up) four feet to put both wheels on your ramp.
  • For years, I've been carrying enough 2X8's to level up to three inches. I recently heard about these (Andersen levelers). They appear to do a pretty good job at leveling, they're lighter, and take up less space than the 2X's. I bought two. Haven't used them, yet.
