IAMICHABOD wrote:
I always put the leveling blocks under both wheels but have found that the Lynx type of blocks have a tenancy to break on soft surfaces and are a pain to assemble. So I prefer the one piece Camco Tri-Leveler
IMO the Tri-Leveler is a bad solution for leveling. The flat areas on each step are way too short to support the normal road contact area of the tire. This puts extra stress on the portion of the tire that is resting on the step. The pictures on the
Camco web site dramatically show this poor support, with half of the normal tire contact area hanging off the step. The first picture also shows the very high stress point where the tire is crushed at the edge of the step. The narrow contact area at the edge is carrying nearly the entire load on the tire, which could cause damage to the tire cords.
Lynx levelers also have an issue with proper support of the full tire contact patch, as there is a large recessed area in the center of the block that provides no support. I made some 1/2" plywood inserts to fill this gap and properly support the tire contact area. I assume that the Lynx Caps would do the same.
