DutchmenSport
Nov 07, 2018Explorer
My last 3 camper (TT and 5er) all had the automatic switch over. I always ran only one tank at a time by keeping the tank valve closed on one and open on the other. This way I knew when one was empty and could get it filled immediately. I never ran short on propane.
And yes, you should be able to disconnect one tank from the line with the other tank turn open and the open line should not leak.
It's an easy test. Just remove one line from one tank and turn the knob on the other tank. See if anything spews out. If not, you are good to go.
44,071 PostsLatest Activity: Aug 30, 2026
