Buzzcut1
Aug 19, 2017Nomad II
When I went from SRW to Dually I bought some brand new Atwood swing out brackets. Total install time was about 30 minutes using a box end wrench and a ratchet set and a carpenters level. It's not rocket science: unbolt the jack add the bracket to tc check for alignment tighten. add jack, check alignment tighten and plug in electrical.
My only hesitation would be if the set you bought did not mate up with the brand on the TC. Find the TC you want buy it, then order the right extensions get them in your hands, then go pick the tc.
