My comments covered the possibility the OP was interested in changing
their OEM's ratings...
Cousin in the Calif Highway Patrol used to check ratings vs actual
weights with portables and had his troopers likewise...he quit after
one too many accidents where he had to pickup pieces of folks. The
final straw was when one of his troopers had his legs cut off by
those bumper shocks of the 70's
He also got many complaints sent to his boss and the reps' for
the region...his boss didn't ding him for any of that
Buddy has a F350 Superduty SRW and gone to 19.5's on his first
set. Now even larger 19.5's. He carries a huge Lance and tows
a V-utility hauling his quads or tows his Jeep. Larger tire because the
first set wore out quickly...even though they were rated for it.
He off roads a lot with me and we take our rigs up to Tahoe (Rubicon) often.
He does NOT care about OEM ratings and just how well it handles
and wears...
His V10 is now showing signs of wearing out by consuming engine
oil...but he understands and will rebuild soon with my help...
flyairam wrote:
Sir,
My dilemma was almost exactly the same as yours; a paid-for well-equipped truck (2006 with 40,000 miles!), but preparing to buy a large RV. My fifth-wheel weighs within a few hundred pounds of yours and my RV garage is large enough for RV and truck, but not large enough for a dually.
After doing the research on my truck's running gear, sticker weights, and safe weights, I decided a tire upgrade was all I needed. I bought Vision Hauler 81 19.5 inch wheels from duallywheels4u and am very happy with this decision. The truck handles the RV very well with no stability problems whatever. It's actually more stable loaded than unloaded; these tires are designed to carry weight-and lots of it.
Without looking at your specific numbers, if your GM is like my Dodge, your axle is rated at something near 10,000 pounds. That leaves the tires as the weakest link, a legitimate safety concern.
Another poster (no names, no insult intended) suggested you would spend a lot of time or money to re-certify your weight capability. That's akin to re-certifying your toaster; nobody does it, nobody cares to do it, and nobody is overseeing that process (I'm LEO).
As for weighing your rig, a simple search will give you the answers to that question. It's easy but requires a little hassle of hooking, unhooking, etc.
Good luck with your decision.
Randy
I have a 2011 Chevy 3500HD diesel, crew cab, long box, single rear wheel (SRW), 18,500 towing capabilities. I have seen conversion kits to convert my SRW to a dually, has anyone done this this? If so, are you happen with the results? I bought a 41 ft Heartland Big Horn 3750FL, 16K gvwr and I'm pushing the load capabilities for the SRW tires. I want to feel a little more secure with the camper load distribution on four dually tires vs. two. Any problems with this thinking?
Also, how can one weight the truck and camper to determine the pin weight? Thanks for your positive input and comments.
