djgExplorerSep 01, 2018Dually leveling questionJust wondering when you level your dually do you use blocks under all 4 rear wheels or just the 2 outside ones, does it matter. Dave
Kayteg1Explorer IISep 01, 2018When you put plank only on 1 side - the tire will flex under excessive load, so you have to put double planks to get single plank lift. You get +- the same lift when putting those 2 planks under each wheel one and the truck will rock less.
Related Contentleveling a duallyLeveling QuestionDually questionsDually LevelingRight rear leveler not retracting fully
