djg
Sep 01, 2018Explorer
Dually leveling question
Just wondering when you level your dually do you use blocks under all 4 rear wheels or just the 2 outside ones, does it matter. Dave
Optimistic Paranoid wrote:
If you've got one of a pair of dually tires sitting on thin air, then obviously the other tire is carrying ALL the weight.
So do you know how much weight each wheel position is carrying? And do you know how much weight a single wheel is rated to carry, at the air pressure you have in it?
If you can answer those two questions, then the answer to your question should be obvious.
