djg
Sep 02, 2018Explorer
Dually leveling question
Just wondering when you level your dually do you use blocks under all 4 rear wheels or just the 2 outside ones, does it matter.
Dave
Dave
As mentioned previously. It's a static load. You're not going to hurt the tire or rim if it's just sitting with additional load on it, over its rated capacity.
Maybe other reasons to block both tires...soft ground, less flex or sway when using the camper, but that's negated by dropping a couple of the camper jacks to stabilize.
Optimistic Paranoid wrote:
If you've got one of a pair of dually tires sitting on thin air, then obviously the other tire is carrying ALL the weight.
So do you know how much weight each wheel position is carrying? And do you know how much weight a single wheel is rated to carry, at the air pressure you have in it?
If you can answer those two questions, then the answer to your question should be obvious.
