ruthiebaby88
Nov 28, 2014Explorer
Dually payload??
How do I figure a dually payload? I drove one and the sticker inside said the cargo rating is 2482#. Do you multiply x2 since it's a dually?
arto_wa wrote:bighatnohorse wrote:wintersun wrote:
. . . and the tires should handle at least 11,000 lbs. . .
This is a limited truth.
And I'm not sure about that!
It could apply when all four dually rear tires are on a level surface with weight evenly distributed on all four.
According to Michelin: Their LT235/85R16 LRE XPS Traction tires, when in dual configuration (or 4 tires per axle), the maximum axle loading is 11,112 lbs.
Wintersun is absolutely correct!
