ruthiebaby88
Nov 28, 2014Explorer
Dually payload??
How do I figure a dually payload? I drove one and the sticker inside said the cargo rating is 2482#. Do you multiply x2 since it's a dually?
ruthiebaby88 wrote:
I just thought it was strange that a DRW 1 ton GMC Sierra would have a max payload of 2482#?
GVWR of 10000, GAVR 4500, GAWR 7500
The tires are 16s.
The truck did seem huge, very long - do you think they used up the weight with an extra long bed?
KD4UPL wrote:
If you're looking at a 2001 - 2010 Chevy the GVWR should be 11,400. The truck empty probably weights about 7,500. This should leave you around 3,900 pounds of payload. Even subtracting for people should leave over 3,000 pounds for payload.
KD4UPL wrote:
My own 2005 Chevy dually is rated for 11,400 but scales at about 13,200 with my family, 11' TC, and boat hitched up. I'm not over the ratings of my tires or axles. I've got many thousands of miles behind me with this set up.
plock40 wrote:
hello, I own a 2013 st ram 3500 4x4 long bed crew cab dually and the door sticker says gvwr is 14000 lbs. i loaded my a/f 990 with full water, propane and gas in truck with food and all camping gear, plus 2 bikes on front, minus wife and i, maybe 300lbs and the total weight 13480. the camper sticker says camper weights 3526. i guess i am under weight by 220 lbs, would that be about right, thanks
