towpro
Oct 10, 2019Explorer
interested to see what you find broke. in my 20's I had a Pontiac with a 350 cid. at the end of its life, just before scrapping it we drained the oil out, put a brick on the throttle and started the engine to see what would happen. After 15 minutes it was still screaming so I got tired of the noise and turned the key off.
I bet there was a catastrophic hard part failure like a rod big end that broke, the oil light came on when the rod cap let all the oil pressure out. but the engine seized when parts of the rod got jammed into the crank/block. Did any holes open up in block?
