- Eric_LisaExplorer II
Grit dog wrote:
Cool. So the answer is yes or no or depends.
I think there is a difference between "tent-only" and "no hookups" campsites. While a "no hookup" works for a self-contained RV and has a tent pad, a "tent-only" probably means just that.
HTH,
-Eric - GeoBoyExplorer
That’s right.:B - toedtoesExplorer III
Yep. That's basically it. Too many variables by region, type of campground, biases of camp hosts, and so on, to have a single answer.
Best thing is to ask politely and accept the answer politely at each campground. Don't take a no answer personally. And just enjoy your camping. - Check with the person in charge. Expect to camp like those around you with probably no generator.
- Grit_dogTrailblazerCool. So the answer is yes or no or depends.
towpro wrote:
look at the other side of the coin. If I am tent camping, I don't want to have to listen to the noise and light pollution caused by RV's
heater cycling all night
hot water heater running
water pump cycling on and off at night
TV's running
worse yet Generators running
lights turned on all night.
ON the other hand as an RV owner I avoid tent sites because they seem to have a higher rate of late night partying. I realize in some spots if the nation its inherently cooler (like out west during summer) but I have seen people with tents running generators so they can have AC in the tent.
I've seen and heard tenters using generators for all sorts of things - including lights (all night), AC or heaters, tv or stereos or projectors for movies, fridges, etc.
At the smaller campgrounds I visit (under 50 sites), tenters are mixed in with RVers with no problem. Usually a tent only site designation is made dependent upon tree growth over the sites and varies each year.
At larger campgrounds (over 100 sites), there are tent only loops that have the group parking pad and you walk a ways to each site.
At none of these campgrounds are there "RV only sites" - whether hookups or not. - DuallyExplorer
towpro wrote:
ON the other hand as an RV owner I avoid tent sites because they seem to have a higher rate of late night partying. .
That has been my experience, BTW in FL state parks for the most part if you fit in the site it is ok to camp in it - towproExplorerlook at the other side of the coin. If I am tent camping, I don't want to have to listen to the noise and light pollution caused by RV's
TV's running
ON the other hand as an RV owner I avoid tent sites because they seem to have a higher rate of late night partying. I realize in some spots if the nation its inherently cooler (like out west during summer) but I have seen people with tents running generators so they can have AC in the tent. - BradWExplorer IIWe have stayed at many "tent only" site in our truck camper. Never had a problem if it fits in the parking spot.
- jimh406Explorer IIIIn WA, State Parks haven’t cared if I parked my Truck Camper or not in Tent areas. In those areas, tent just means no rv pad and no improvement for RVs. However, Yellowstone explicitly calls my rig an RV. That means no camping at Tent spots according to the guys on the reservations, and also means no driving on roads that don’t allow RVs if my Truck Camper is on.
BTW, I’ve been down a few of the roads in Yellowstone when I took off my Truck Camper. I can’t imagine a problem driving them with the Truck Camper. I think it’s just simpler to so no which I’m ok with.
Sure, it’s kind of arbitrary, but those are the rules as far as I can tell. There are also explicit hard side camper areas in Yellowstone if Fishing Bridge is open.
Once upon a time, I think the intent was to separate the quiet tent campers from the RVs, but as noted, that isn’t very real any more. There are just as many loud tent campers as loud RV campers.
