Golden_HVAC
Jun 14, 2013Explorer
When running the electric heater, on high it might draw very close to 15 amps, so best to run it on low heat. The refrigerator is about a 3 amp load (unless on gas only) and water heater if you have electric option is between 8 and 10 amps. TV is typically only about 1 amp.
Big users are the microwave - 12.5 amps even if you are running only 50% power, it actually runs at 100% for only 50% of the time if set to 50% power.
Coffee maker, toaster, and such have a amp rating on the bottom or other label. Should be in the 1000 watt range or about 10 amps each, so don't try running more than 1 at a time if on 15 amps, or 2 at a time if on 30 amps.
Air conditioner can use between 12 and 15 amps, the warmer it is outside, the more amps it will consume..
Fred.
Fred.
